Sponsors
Affiliates
<< 1953
1955 >>
1954 Corvette Specifications
Wheelbase 102.0 in
Track Frt/Rear (in) 57.0/59.0
Length 167.0 in
Width 72.24 in
Height 51.25 in
Frontal Area NA
Ground Clearance 6.0 In.
Curb Weight 2850 lbs
Weight Dist. F/R (Engine) NA
Coolant Capacity 17.75 qt.
Fuel Capacity 17.25 gal.
Oil Capacity 5.0 qt.
Engine Options & Specifications
Type OHV, in-line 6 cylinder, water cooled, cast iron block, 4 mains.
Bore 3.56 in
Stroke 3.94 in
Displacement 235.5 ci
Compression Ratio 8.0:1
Horsepower 150 bhp @ 4200 rpm
Torque 223 lb-ft @ 2400 rpm
Redline NA
Carburetion 3 sidedraft Carter Carbs.
Valvetrain Hydraulic
Check out the Corvette Action Center's edition of the Tire Rack Upgrade Garage!
