Sponsors
Affiliates
CarFax
<< 1957
1959 >>
1958 Corvette Identification
VIN Tag Information
J58S100001 - J58S109168
Digit Definition
1st Series/Model:  = 800/J = Corvette
2nd / 3rd Model Year = 58
4th Assembly Plant  S = St. Louis, MO.
Last 6 digits Production Number starting with 100001 - 109168.
Engine Suffix ID Numbers
CQ: 283ci, 230hp, (manual transmission)
CR: 283ci, 250hp, (manual transmission)
CS: 283ci, 290hp (manual transmission)
CT: 283ci, 245hp (manual transmission)
CU: 283ci, 270hp (manual transmission)
DG: 283ci, 230hp, (automatic transmission)
DH: 283ci, 250hp (automatic transmission)
DJ: 283ci, 245hp (automatic transmission)
Block ID Numbers
373779 or 3756519: All Engines
Head ID Numbers
3748770: All Engines (staggered valve cover holes)
Carburetor ID Numbers
Carter 2613S #3741089: 283ci, 270hp (front carburetor)
Carter 2614S #3741090: 283ci, 270hp (rear carburetor)
Carter 2626S #3744002: 283ci, 245hp (front carburetor)
Carter 2627S #3744004: 283ci, 245hp (rear carburetor)
Carter 2669S #3746384: 283ci, 230hp
Distributor ID Numbers
1110890: 283ci, 230hp
1110891: 283ci, 220hp, 245hp, 270hp
1110908: 283ci, 290hp (early production)
1110914: 283ci, 290hp
1110915: 283ci, 250hp
Fuel Injection ID Numbers
Rochester 7014800: 283ci, 250hp
Rochester 7014800R: 283ci, 290hp (early production)
Rochester 7014900: 283ci, 250hp,
Rochester 7014900R: 283ci, 290hp
Rochester 7014960: 283ci, 290hp
Rochester 7017200: 283ci, 250hp (late production)
Generator ID Numbers
1102043: 283ci, 230hp, 245hp, 250hp, 270hp
1102059: 283ci, 290hp
Check out the Corvette Action Center's edition of the Tire Rack Upgrade Garage!
