Forums
Register now for the Corvette Action Center's Corvette Forum!
Affiliates
Supporting Vendors / Dealers - Supporting Membership - Advertising Information
<< 1959
1961 >>
1960 Corvette Specifications
Wheelbase 102 in.
Track Frt/Rear (in) 57/59
Length 177.2 in.
Width 72.8 in.
Height 51"
Frontal Area 340 sq. in.
Ground Clearance 5.8 in.
Curb Weight 2,985 lbs.
Weight Dist. F/R (Engine) 53/47
Fuel Capacity 16.4 gal.
Coolant Capacity 16.5 qt.
Engine Options & Specifications
  Base 469 469C 579 579D
Bore 3.875 in.
Stroke 3.00 in.
Displacement 283 ci 283 ci 283 ci 283 ci 283 ci
Compression Ratio 9.5:1 9.5:1 9.5:1 9.5:1 10:1
Horsepower 230 bhp 245 bhp 270 bhp 250 bhp 290 bhp
Torque 300 lb-ft @ 3,000 rpm 300 lb-ft @ 3,800 rpm 285 lb-ft @ 4,200 rpm 305 lb-ft @ 3,800 rpm 290 lb-ft @ 4,400 rpm
Redline 5,300 rpm 5,300 rpm 6,300 rpm 5,300 rpm 6,300 rpm
Carburetion 1x4 bbl 2x4 bbl 2x4 bbl Fuel Inj. Fuel Inj.
Oil Capacity 6 quarts
Valvetrain hydraulic hydraulic mechanical hydraulic mechanical
Check out the Corvette Action Center's edition of the Tire Rack Upgrade Garage!
