Sponsors
Affiliates
Supporting Vendors / Dealers - Supporting Membership - Advertising Information
<< 1961
1963 >>
1962 Corvette Specifications
Wheelbase 102 in.
Track Frt/Rear (in) 57/59
Length 177.2 in.
Width 72.8 in.
Height 52.2 in.
Frontal Area 315.4 sq. in.
Ground Clearance 6.7 in.
Curb Weight 2,925 lbs
Weight Dist. F/R (Engine) 52/47
Fuel Capacity 16.4 gal.
Coolant Capacity 16.5 qt.
Engine Options & Specifications
  Base 396 582 583
Bore 4.00 in.
Stroke 3.25 in.
Displacement 327 ci 327 ci 327 ci 327 ci
Compression Ratio 10.5:1 11.25:1 11.25:1 10.5:1
Horsepower 250 bhp 340 bhp 360 bhp 300 bhp
Torque 350 lbs-ft @ 2800 rpm 344 lbs-ft @ 4000 rpm 352 lbs-ft @ 4000 rpm 360 lbs-ft @ 3200 rpm
Redline 5300 rpm 6300 rpm 6300 rpm 5300 rpm
Carburetion 4-bbl Carter AFB Carb. 4-bbl Carter AFB Carb. Fuel Inj. 4-bbl Carter AFB Carb.
Oil Capacity 6 quarts
Valvetrain hydrayulic mechanical mechanical hydrayulic
Check out the Corvette Action Center's edition of the Tire Rack Upgrade Garage!
