Sponsors
Affiliates
CarFax
<< 1962
1964 >>
1963 Corvette Specifications
  Coupe Convert.
Wheelbase (in.) 98.0
Track Frt/Rear (in.) 56.3 / 57
Length (in.) 175.3
Width (in.) 69.6
Height (in.) 49.8
Frontal Area (in.) 19.3
Ground Clearance (in.) 5.0
Curb Weight (lbs.) 3,048 3,030
Weight Dist. F/R 48 / 52
Fuel Capacity (gal.) 20.0
Transmission
  Base M20 M35
Type 3-Speed Man. 4-Speed Man. 4-Speed Auto.
Gear Ratios
1st 2.47 NA 2.20
2nd 1.53 NA 1.66
3rd 1.00 NA 1.31
4th NA NA 1.00
Reverse NA NA NA
Axle Ratio NA NA NA
Final Drive Ratio NA NA NA
Engine Options & Specifications
NA Base L75 L76 L84
Bore 4.00 in.
Stroke 3.25 in.
Displacement 327 ci
Compression Ratio 10.5:1 10.5:1 11.25:1 11.25:1
Horsepower 250 bhp @ 4,400 rpm 300 bhp @ 5,000 rpm 340 bhp @ 6,000 rpm 360 bhp @ 6,000 rpm
Torque 350 lb-ft. @ 2,800 rpm 360 lb-ft. @ 3,200 rpm 344 lb-ft. @ 4,000 rpm 352 lb-ft. @ 4,000 rpm
Redline NA NA NA NA
Carburetion 1 x 4 bbl. 1 x 4 bbl. AFB 1 x 4 bbl. AFB Ramject Fuel Injection
Oil Capacity NA NA NA NA
Valvetrain NA NA NA NA
More Specifications Coming Soon!
Check out the Corvette Action Center's editio of the Tire Rack Upgrade Garage!
