Sponsors
Affiliates
CarFax
<< 1963
1965 >>
1964 Corvette Identification
VIN Tag Information
40837S100001 - 40837S122229 (coupe)
40867S100001 - 40867S122229 (convertible)
Digit Definition
1st Model year:  4 = 1964
2nd / 3rd Series:  08 = Corvette
4th/5th Body Style:  37 = 2-door coupe, 67 = 2-door convertible
6th Assembly Plant:  S = St. Louis, MO.
Last 6 digits Production Number starting with 100001 - 122229
Engine Suffix ID Numbers
RC: 327ci, 250hp, (manual transmission)
RD: 327ci, 300hp, (manual transmission)
RE: 327ci, 365hp (manual transmission)
RF: 327ci, 375hp (manual transmission)
RP: 327ci, 250hp, (manual transmission)
RQ: 327ci, 300hp, (manual transmission)
RR: 327ci, 365hp (manual transmission)
RT: 327ci, 365hp (manual transmission, transistor ignition)
RU: 327ci, 365hp (air conditioning, manual transmission, transistor ignition)
RX: 327ci, 375hp, (manual transmission, transistor ignition)
SC: 327ci, 250hp (automatic transmission)
SD: 327ci, 300hp, (automatic transmission)
SK: 327ci, 250hp (air conditioning, automatic transmission)
SL: 327ci, 300hp, (air conditioning, automatic transmission)
Block ID Numbers
3782870: All Engines
Head ID Numbers
3782461: 327ci, 300hp, 365hp, 375hp
3795896: 327ci, 250hp
Carburetor ID Numbers
Carter 3696S #3846246: 327ci, 300hp (automatic transmission)
Carter 3697S #3846247: 327ci, 300hp, 340hp (manual transmission)
Carter 3720S/SA/SB #3851762: 327ci, 250hp (automatic transmission)
Carter 3721S/SA/SB #3851761: 327ci, 250hp (manual transmission)
Holley R2818A #3849804: 327ci, 365hp
Alternator ID Numbers
1100628: 327ci (early production, limited use)
1100665: 327ci, 250hp, 300hp, 365hp (air conditioning)
1100668: 327ci
1100669: 327ci, 365hp, 375hp (transistor ignition)
1100684: 327ci, 365hp (air conditioning, transistor ignition)
Distributor ID Numbers
1111024: 327ci, 250hp, 300hp
1111060: 327ci, 365hp (transistor ignition)
1111062: 327ci, 365hp (early production)
1111063: 327ci, 375hp (early production)
1111064: 327ci, 375hp (transistor ignition)
1111069: 327ci, 365hp (late production)
1111070: 327ci, 375hp (late production)
Fuel Injection ID Numbers
Rochester 7017375 (early production)
Rochester 7017375R (limited use)
Rochester 7017380 (late production)
Check out the Corvette Action Center's editio of the Tire Rack Upgrade Garage!
