Sponsors
Affiliates
<< 1964
1966 >>
1965 Corvette Specifications
Engine Options & Specifications
  Base L75 L76 L78 L79 L84
Bore 4.00 (102 mm) 4.00 (102 mm) 4.00 (102 mm) 4.00 (102 mm) 4.00 (102 mm) NA
Stroke 3.25 (83 mm) 3.25 (83 mm) 3.25 (83 mm) 3.25 (83 mm) 3.25 (83 mm) NA
Displacement 327 ci 327 ci 327 ci 396 ci 327 ci 327 ci
Compression Ratio 10.5:1 10.5:1 NA 11.0:1 11.0:1 NA
Horsepower 250 bhp @ 4400 rpm 300 bhp @ 5000 rpm 365 bhp @ 6200 rpm 425 bhp @ 6400 rpm 350 bhp @ 5500 rpm 375 bhp @ 6200 rpm
Torque 350 lbs-ft. @ 2800 rpm 360 lbs-ft. @ 3200 rpm 350 lbs-ft. @ 4000 rpm 415 lbs-ft. @ 4000 rpm 360 lbs-ft. @ 3600 rpm 350 lbs-ft. @ 4600 rpm
Redline NA NA NA NA NA NA
Carburetion NA Single 4 BBl. Carb. NA HC Large 4 Bbl. Carb. Single - four throat Holley Carb. Fuel Injected
Oil Capacity NA NA NA NA NA 4 qt.
Valvetrain NA NA NA Mechanical lifters Hydraulic lifters NA
Mileage NA NA NA NA 10-18 mpg NA
More 1965 Corvette Specifications Coming Soon!
