1973 Corvette Powertrain Specifications
Below is listing of 1973 Corvette engine specifications.
Powertrain Combinations
Engine Transmission Positraction Axle Ratios (*)
3.08:1 3.36:1 3.55:1 3.70:1
Turbo-Fire 350
350 Cu.In. V8
Standard
4-Speed (2.52:1 low) Opt Std
Turbo Hydra-matic Std Opt
Turbo-Fire 350
350 Cu.In. V8
RPO L82
4-Speed (2.52:1 low)     Std Opt
4-Speed (2.20:1 low)     Opt Std
Turbo-Jet 454
454 Cu.In. V8
RPO LS4
4-Speed (2.20:1 low) Opt Std Opt
(*)Air conditioning available with all transmission/axle combinations except with 3.70 axle ratio.
Multiplication Factors
With Manual Transmission
Engine Transmission Total Gear Reduction Axle Ratio
1st 2nd 3rd 4th Rev
350 Cu.In. V8
Standard
4-Speed (2.52:1) 8.47 6.32 4.91 3.36 8.70 3.36
350 Cu.In. V8
RPO L82
4-Speed (2.52:1) 8.95 6.67 5.18 3.55 9.19 3.55
4-Speed (2.20:1) 8.14 6.07 4.70 3.70 8.36 3.70
454 Cu.In. V8
RPO LS4
4-Speed (2.52:1) 7.76 5.79 4.50 3.08 7.98 3.08
4-Speed (2.20:1) 7.39 5.51 4.27 3.36 7.59 3.36
With Automatic Transmission
Engine Transmission
Selector
Position
Total Torque *
Multiplication
Axle Ratio
350 Cu.In. V8
Standard
Turbo
Hydra-matic
Drive 16.05:1 - 3.08:1
3.08:1
Low 16.05:1 - 7.64:1
Second 16.05:1 - 4.56:1
Reverse 13.46:1 - 6.41:1
350 Cu.In. V8
RPO L82
Turbo
Hydra-matic
Drive 18.50:1 - 3.55:1 3.55:1
Low 18.50:1 - 8.80:1
Second 18.50:1 - 5.25:1
Reverse 15.51:1 - 7.38:1
454 Cu.In. V8
RPO LS4
Turbo
Hydra-matic
Drive 16.05:1 - 3.08:1 3.08:1
* - Axle Ratio x transmission ratio.
