Below is a complete listing of 1980 Corvette specifications including engine, chassis, suspension specs and more.
Wheelbase (in.) 98.0
Track Frt/Rear (in) 58.7 / 59.5
Length (in.) 185.3
Width (in.) 69.0
Height (in.) 48.1
Frontal Area (in) NA
Ground Clearance (in.) (minimum) 3.9
Curb Weight (lbs) 3282
Weight-to-power ratio (lbs:hp) NA
Coefficient of Drag 0.443
Weight Dist. F/R (%) 48 / 52
Coolant Capacity (qt.) 21.6
Fuel Capacity (gal.) 24.0
Oil Capacity (qt.) 4.6
Engine Specifications
  L48 LG4 L82
Type Overhead valve, 350 ci, pushrod V8, 2 valves/cylinder
Bore 4.00 in. 3.74 in. 4.00 in.
Stroke 3.48 in. 3.48 in. 3.48 in.
Displacement 350 ci. 305 ci. 350 ci.
Compression Ratio 8.2:1 8.5:1 9.0:1
Horsepower 190 hp @ 4200 rpm 180 hp @ 4200 rpm 230 hp @ 5200 rpm
Torque 270 lb-ft @ 2400 rpm 255 lb-ft @ 2000 rpm 260 lb-ft @ 3600 rpm
Redline (RPM) NA NA NA
Induction System 4 bbl Carb. 4 bbl Carb. 4 bbl Carb.
Valve Lifters Hydraulic Hydraulic Hydraulic
Miscellaneous
Brakes
Type NA
Front Rotors (diam. x thickness)(mm) NA
Rear Rotors (diam. x thickness)(mm) NA
Transmission
  Automatic Manual
Type 4-Speed Automatic (MM4) 4-Speed Manual
Gear Ratios
1st NA 2.88
2nd NA 1.91
3rd NA 1.33
4th NA 1.00
Reverse NA NA
Axle Ratio NA NA
Final Drive Ratio 3.07:1
