Sponsors
Affiliates
CarFax
<< 1991
1993 >>
1992 Corvette Specifications
  Coupe Convert. ZR-1
Wheelbase (in.) 96.2
Track Front 57.7
Track Rear 59.0 60.6
Length (in.) 178.5
Width (in.) 70.7 73.1
Height (in.) 46.3 47.3 46.3
Ground Clearance (in.) 4.2 3.6 4.2
Curb Weight (lbs) 3,317 3,358 3,503
Coefficient of Drag NA NA NA
Weight Dist. F/R (%) 51.5/48.5 NA NA
Engine Specifications
  LT1 LT5
Type Overhead valve, pushrod V8, 2 valves/cylinder, cast iron block, aluminum heads Double Overhead Cam, 32-valve, V8, 4 valves/cylinder, aluminum block and heads
Bore 4.00 in 3.90 in
Stroke 3.48 in 3.66 in
Displacement 5.7L / 350 ci.
Compression Ratio 10.5:1 11.0:1
Horsepower 300 hp @ 5,000 RPM 375 hp @ 6,000 RPM
Torque 330 lb-ft @ 4,000 RPM 370 lb-ft @ 4,800 RPM
Redline (RPM) 5,500 7,100
Induction System Bosch Multi-port Fuel Injection
Coolant Capacity (qt.) 14.5 (man.) / 14.6 (auto) 16.7 (ZR-1)
Fuel Capacity (gal.) 20.0
Fuel Economy City/Hwy (EPA) 17/25 mpg (LT1 w/ man. trans.) 17/25 mpg
Oil Capacity (qt.) crankcase 4.0 8.55
Miscellaneous
Brakes
Type ABS Power-assist vented discs
Front Rotors (diam) 12.0 x 0.8 in. (excl. ZR-1)
13.0 x 0.8 (ZR-1)
Rear Rotors (diam) 12.0 x 0.8 in.
Wheels and Tires
Wheel Size (Front) 17 x 9.5 in. (all models)
Wheel Size (Rear) 17 x 9.5 in. (excl. ZR-1)
17 x 11 in. (ZR-1)
Wheel Type 5-bolt, cast aluminum
Tire Make/Size Front:  Goodyear Eagle GSC, P275/40ZR-17 (all models)
Rear:  Goodyear Eagle GSC, P275/40 ZR-17 (excl. ZR-1), P315/35ZR-17 (ZR-1)
Transmission
  Automatic Manual
Type 4-Speed Automatic 6-spd Manual
Gear Ratios
1st 3.06 2.68
2nd 1.63 1.80
3rd 1.00 1.31
4th 0.70 1.00
5th NA 1.33 (0.89 OD)
6th NA 0.50
Reverse 2.29 .50
Axle Ratio 2.59 3.45
Paint Codes
RPO Code Color Valspar Code PPG Code DuPont Code RM Code SW Code MS Code Azko Code WA Code
10 White W243 4185 B8949 19005 40911 - GMA89:10 9567
35 Yellow Y119 3886 B8627 - 35423 - GMA86:35 8769
41 Black K090 9700 99 13572 1738 3069 GMA78:19 8555
43 Bright Aqua Metallic L785 4456 B9201 22253 45732 - GMA92:43 9796
45 Polo Green II Metallic G211 4301 B9012 20011 42596 - GMA91:45 9539
73 Black Rose Metallic K072 4464 B9218 22258 45738 - GMA92:73 9885
75 Dark Red Metallic R183 4177 B8947 19003 40212 - GMA91:75 9239
80 Quasar Blue Metallic L435 4267 B9060 20019 43693 - GMA90:80 9544
81 Bright Red R319 3794 C8508 - 34983 - GMA85:81 8774
Check out the Corvette Action Center's edition of the Tire Rack Upgrade Garage!
