1993 Corvette Specifications
| Dimensions |
Coupe |
Convert. |
ZR-1 |
| Wheelbase (in.) |
96.2 |
| Track Front |
57.7 |
| Track Rear |
59.0 |
60.6 |
| Length (in.) |
178.5 |
| Width (in.) |
70.7 |
73.1 |
| Height (in.) |
46.3 |
47.3 |
46.3 |
| Ground Clearance (in.) |
4.2 |
3.6 |
4.2 |
| Curb Weight (lbs) |
3,317 |
3,358 |
3,503 |
| Coefficient of Drag |
NA |
NA |
NA |
| Weight Dist. F/R (%) |
51.5/48.5 |
NA |
NA |
| Engine Specifications |
LT1 |
LT5 |
| Type |
Overhead valve, pushrod V8, 2 valves/cylinder, cast iron block, aluminum heads |
Double Overhead Cam, 32-valve, V8, 4 valves/cylinder, aluminum block and heads |
| Bore |
4.00 in |
3.90 in |
| Stroke |
3.48 in |
3.66 in |
| Displacement |
5.7L / 350 ci. |
| Compression Ratio |
10.5:1 |
11.0:1 |
| Horsepower |
300 hp @ 5,000 RPM |
405 hp @ 5,800 RPM |
| Torque |
340 lb-ft @ 4,000 RPM |
385 lb-ft @ 4,800 RPM |
| Redline (RPM) |
5,500 |
7,100 |
| Induction System |
Bosch Multi-port Fuel Injection |
| Coolant Capacity (qt.) |
14.5 (man.) / 14.6 (auto) |
16.7 (ZR-1) |
| Fuel Capacity (gal.) |
20.0 |
| Fuel Economy City/Hwy (EPA) |
17/25 mpg (LT1 w/ man. trans.) |
17/25 mpg |
| Oil Capacity (qt.) crankcase |
4.0 |
8.55 |
| Miscellaneous |
| Brakes |
| Type |
ABS Power-assist vented discs |
| Front Rotors (diam) |
12.0 x 0.8 in. (excl. ZR-1) 13.0 x 0.8 (ZR-1) |
| Rear Rotors (diam) |
12.0 x 0.8 in. |
| Wheels and Tires |
| Wheel Size (Front) |
17 x 8.5 in. (base) 17 x 9.5 (ZR-1) |
| Wheel Size (Rear) |
17 x 9.5 in. (base) 17 x 11 in. (ZR-1) |
| Wheel Type |
5-bolt, cast aluminum |
| Tire Make/Size |
Front: Goodyear Eagle GSC, P255/40ZR-17 (base), P275/40ZR-17 (ZR-1) Rear: Goodyear Eagle GSC, P285/40 ZR-17 (base), P315/35ZR-17 (ZR-1) |
| Transmission |
Automatic |
Manual |
| Type |
4-Speed Automatic |
6-spd Manual |
| Gear Ratios |
| 1st |
3.06 |
2.68 |
| 2nd |
1.63 |
1.80 |
| 3rd |
1.00 |
1.31 |
| 4th |
0.70 |
1.00 |
| 5th |
NA |
1.33 (0.89 OD) |
| 6th |
NA |
0.50 |
| Reverse |
2.29 |
0.50 |
| Axle Ratio |
2.59 |
3.45 |
| Paint Codes |
| RPO Code |
Color |
Valspar Code |
PPG Code |
DuPont Code |
RM Code |
SW Code |
MS Code |
Azko Code |
WA Code |
| 10U |
White |
W243 |
4185 |
B8949 |
19005 |
40911 |
GMA89:10 |
9567 |
| 41U |
Black |
K090 |
9700 |
99 |
13572 |
1738 |
3069 |
GMA78:19 |
8555 |
| 4U3 |
Bright Aqua Metallic |
L785 |
4456 |
B9201 |
22253 |
45732 |
GMA92:43 |
9796 |
| 45U |
Polo Green II Metallic |
G211 |
4301 |
B9012 |
20011 |
42596 |
GMA91:45 |
9539 |
| 53U |
Competition Yellow |
Y187 |
4266 |
B9058 |
20028 |
43691 |
GMA90:53 |
9804 |
| 68U |
Ruby Red |
R1106 |
4708 |
23019 |
46833 |
GMA93:68 |
5392 |
| 70U |
Torch Red |
R311 |
4230 |
B9008 |
20002 |
42027 |
GMA91:70 |
9075 |
| 73U |
Black Rose Metallic |
K072 |
4464 |
B9218 |
22258 |
45738 |
GMA92:73 |
9885 |
| 75U |
Dark Red Metallic |
R183 |
4177 |
B8947 |
19003 |
40212 |
GMA91:75 |
9239 |
| 80U |
Quasar Blue Metallic |
L435 |
4267 |
B9060 |
20019 |
43693 |
GMA90:80 |
9544 |
