2007 Corvette Specifications
For Release: August 1, 2006
Source: GM Media
Overview
Models:
Chevrolet Corvette Coupe, Convertible and Z06
Body styles / driveline:
2-door hatchback coupe with removable roof; rear-wheel drive (Coupe and Convertible)
2-door hatchback coupe with fixed roof; rear-wheel drive (Z06)
Construction:
composite body panels, hydroformed steel frame with aluminum and magnesium structural and chassis components (coupe);
composite and carbon-fiber body panels, hydroformed aluminum frame with aluminum and magnesium structural and chassis components (Z06)
Manufacturing location:
Bowling Green, Ky.
Engines
6.0L V-8 LS2
7.0L V-8 LS7 (Z06)
Displacement (cu in / cc):
364 / 5970
427.6 / 7008
Bore & stroke (in / mm):
4 x 3.62 / 101.6 x 92
4.125 x 4 / 104.8 x 101.6
Block material:
cast aluminum
cast aluminum
Cylinder head material:
cast aluminum
cast aluminum
Valvetrain:
overhead valve, 2 valves per cylinder
Fuel delivery:
SFI (sequential fuel injection)
Compression ratio:
10.9:1
11:1
Horsepower
(hp / kW @ rpm):
400 / 298 @ 6000
505 / 377 @ 6300*
Torque (lb-ft / Nm @ rpm):
400 / 542 @ 4400
470 / 637 @ 4800*
Recommended fuel:
premium recommended but not required
premium required
Estimated fuel economy
(mpg city / hwy / combined):
manual: 18 / 28 / 22.5
automatic: 17 / 27 / 21.5
16 / 26 / 20.5
Chassis / Suspension
Z06
Front:
short/long arm ( SLA ) double wishbone, cast aluminum upper & lower control arms, transverse-mounted composite leaf spring, monotube shock absorber
Rear:
Traction control:
electronic traction control; Active Handling
Brakes
Z06
Type:
front and rear power-assisted disc with ABS; cross-drilled rotors with Z51 package and Magnetic Ride Control
front and rear power-assisted disc with ABS with 6-piston front and 4-piston rear calipers, cross-drilled rotors
Rotor diameter x thickness (in / mm):
front: 12.8 x 1.26 / 325 x 32
rear: 12 x 1 / 305 x 26;
Z51 Performance Package:
front: 13.4 x 1.26 / 340 x 32
rear: 13 x 1 / 330 x 26
front: 14 x 1.3 / 355 x 32
rear: 13.4 x 1 / 340 x 26
Wheels & Tires
Wheel size:
front: 18 inch x 8.5 inch
rear: 19 inch x 10 inch
front: 18 inch x 9.5 inch
rear: 19 inch x 12 inch
Tires:
Goodyear Eagle F1 Supercar (w/Z51)
Extended Mobility
front: P245/40ZR18
rear: P285/35ZR19
Goodyear Eagle F1 Supercar Extended Mobility
front: P275/35ZR18
rear: P325/30ZR19
Exterior
Z06
Wheelbase (in / mm):
105.7 / 2685
105.7 / 2685
Overall length (in / mm):
174.6 / 4435
175.6 / 4460
Overall width (in / mm):
72.6 / 1844
75.9 / 1928
Overall height (in / mm):
49 / 1244
49 / 1244
Curb weight (lb / kg):
Coupe: 3179 / 1442
Conv.: 3199 / 1451
3132 / 1421
Interior
Seating capacity
2
Interior volume (cu ft / L):
52 / 1475 (all models)
Headroom (in / mm):
38 / 962 (all models)
Legroom (in / mm):
43 / 1092 (all models)
Shoulder room (in / mm):
55 / 1397 (all models)
Hip room (in / mm):
54 / 1371 (all models)
Capacities
Cargo volume
(cu ft / L):
Coupe and Z06: 22 / 634
Convertible: 11 / 295 (top up); 7.5 / 212 (top down)
Fuel tank (gal / L):
18 / 68.1
Engine oil (qt / L):
Coupe and Convertible: 5.5 / 5.2
Z06: 8 / 7.5
* Horsepower and torque are SAE certified. A new voluntary power and torque certification procedure developed by the SAE Engine Test Code committee was approved March 31, 2005. This procedure (J2723) ensures fair, accurate ratings for horsepower and torque by allowing manufacturers to certify their engines through third-party witness testing. GM was the first auto manufacturer to begin using the procedure and expects to use it for all newly rated engines in the future.
