1955 - 1958 Corvette: Service Bulletin: Skinner Oil Savers for 1958 and Older Model V-8 Engines
Estimated Reading Time: 1 Minutes Subject: Skinner Oil Savers for 1958 and Older Model V-8 Engines
Model and Year: 1955 - 1958 Corvette
Bulletin No: 46-20-59
Zone: No. 46 - Green Bay, Wis.
Date: June 25, 1959
We are attaching hereto a brochure and order blank for purchasing the Skinner Type Oil Seals which will fit 1955-1958 265" and 283" V-8 Engines. You may use the Order Blank on the attached form to obtain these seals for the correction of excessive oil consumption on these older models.
UNDER NO CIRCUMSTANCES WILL WE ACCEPT L&MR’S FOR CREDIT CONSIDERATION FOR INSTALLING THIS TYPE SEALS UNLESS WRITTEN APPROVAL WAS RECEIVED FROM THIS OFFICE PRIOR TO INSTALLATION.
Please be guided accordingly,
Yours very truly,
R.S. Wiegand
Zone Service Manager
