1955 Corvette: Service Bulletin: Foreign Material in Clutch Housings, Secondary Road Operation
Estimated Reading Time: 1 MinutesSubject: Foreign Material in Clutch Housings, Secondary Road Operation
Model and Year: 1955 Passenger Cars, 3-Speed Transmission
Bulletin Number: DR 217, Section VI
Date: July 25, 1955
Clutch Fork Boot Assemblies are now available in parts stock to prevent entrance of foreign material at the fork opening on V-8 and 6-cylinder 1955 Passenger Cars with 3-speed transmission being used in secondary road operation.
In addition on 6-cylinder units -
- The left hand hole in clutch housing should be closed with Welsh Plug listed below. Welsh Plug is retained by driving into opening.
- The shipping bracket holds in the lower front corners of the flywheel housing should be closed off by installing cap screws.
- The timing pointer hole on right side of clutch housing should be covered with a rubber timing pointer hole plug. Part number listed below.
PARTS
6-Cylinder
Description | Part No. | Quantity |
Clutch Fork Boot | 3723796 | 1 |
1-1/2" Expansion Plug | 103896 | 1 |
Timing Pointer Hold Plug | 3837003 | 1 |
8-Cylinder | ||
Clutch Fork Boot | 3723280 | 1 |
All the above parts have now entered production.
