1955 Corvette: Service Bulletin: New Temperature Gauge
Estimated Reading Time: 2 MinutesSubject: New Temperature Gauge
Model and Year: 1955 Passenger Car - V-8 Models
Bulletin No: DR-222
Section: XII
Date: October 13, 1955
To: All Chevrolet Dealers:
Some overheating complaints on late 1955 Passenger Models equipped with V-8 engines have been received which can be directly attributed to the recalibration of the temperature gauge as no water loss occurs.
The new gauge may operate in a range to the right of the center white dot when the engine has become normalized. The range of operation will vary with various temperature thermostats and a sharp rise can be expected when engine is idled excessively or when just stopped due to residual heat.
As a result of "running cool" on complaints on early V-8 engines, the temperature gauge was recalibrated to provide a more accurate indication of V-8 engine operating temperature.
This change has been in production about 60 days.
SERVICE PARTS
Description * New Part No.
GAUGE - 1513145
Water Temperature
* Gauge, Part No. 1512931, used in early V-8 engines continues to be used in 6 cylinder models.
EL Harrig
