1955 Corvette: Service Bulletin: Oil Level Gauge Dipsticks
Estimated Reading Time: < 1 Minute Subject: Oil Level Gauge Dipsticks
Model and Year: 1955 Powerglide Transmission
Bulletin No: DR-181
Section: VII
Date: November 3, 1954
The following sketch shows the various Oil Level Gauge Dipsticks used with the 1955 Powerglide Transmission.
POWERGLIDE TRANSMISSION DIPSTICK MARKINGS
IMPORTANT - WHEN CHECKING OIL LEVEL
- Engine should be idling.
- Transmission control lever should be in the "N" position.
- Transmission oil should be HOT.
- Use the correct dipstick.
- Check the level accurately.
Overfilling the transmission may cause lubricant loss at the Filler.
