1957 - 1958 Corvette: Service Bulletin: Fuel Economy Drop - Rochester Fuel Injection Service Update
Estimated Reading Time: 1 MinutesSubject: FUEL ECONOMY DROP - #7014800 FUEL INJECTION UNIT
Model and Year: 1957 - 1958 Corvette
Source: Chevrolet Central Office Technical Service bulletin
Bulletin Number: DR #329
Section: VIm
Date: November 21, 1957
Progressive and gradual lowering of Fuel Economy on units equipped with #7014800 Fuel Injection may be due to partial restriction of the .030" venturi signal bleed hole in the air meter.
A dirt build up at this point gradually reduces the amount of signal bleed off, resulting in a progressively stronger venturi signal and increased enrichment.
The following procedure is recommended for cleaning the bleed hole. (Reference 1958 Passenger Car Shop Manual, Page 10-74, Figure 136).
- Remove air cleaner assembly.
- Remove four (4) screws holding air meter diffuser cone and remove diffuser cone only. Do not remove venturi ring.
- Locate bleed hole on the interior surface of the air horn which is positioned on the horizontal centerline, on the rear side of the interior wall, approximately " in from the air cleaner attaching surface.
- Insert a .030" wire at approximately 45o to the surface to clean out the hole.
- Install diffuser cone and air cleaner assembly.
