1957 Corvette: Service Bulletin: 1957 Passenger Car and Truck Camshaft Identification
Estimated Reading Time: 1 Minutes Subject: 1957 Passenger Car & Truck Camshaft Identification
Model and Year: 1957 Passenger Car & Truck
Bulletin Number: DR #292, Section VI, April 29, 1957
Charts on pages 2 and 3 of this bulletin list 1957 Passenger and Truck Camshafts used in the various engines and a means of identification by casting number.
In instances where two casting numbers are given in chart for one engine, the upper number identifies the service shaft and the otehr the production shaft. The service shaft is universal, fitting all models 55 thru 57.
