1959 Corvette: Service Bulletin: Decal Added to Air Cleaner to Aid Installation and Prevent Carburetor Linkage Interference
Subject:   Decal Added to Air Cleaner to Aid Installation and Prevent Carburetor Linkage Interference
Model and Year:   1959 Corvette
Source:  General Motors of Canada Service Bulletin
Bulletin No:  NA
Section:   Page 82
Date:  September 15, 1959
Effective in Production on July 6th, 1959, a deal was added on the top front of the air cleaner assembly to indicate "Front" of the air cleaner and insure proper installation.  This was done so that the recesses in the underpan of the air cleaner, which are provided to allow clearance for the carburetor linkage, will be properly located.  If these recesses are not properly located, the carburetor rods can interfere with the underpan of the air cleaner and cause improper choke closing.  Early air cleaners without decals should be rotated at installation until the carburetor linkage drops into the recesses.
