1963 - 1965 Corvette: Engineering Service Letter: Air Gaps Between Corvette Folding Top
Subject:  Air Gaps Between Corvette Folding Top - Rear Bow Weatherstrip and Body Panel
Model and Year: 1963, 1964, 1965 Corvette
Date:  Dec. 12, 1964
BODY - SECTION 1
ESL’s
AIR GAPS BETWEEN CORVETTE FOLDING TOP - REAR BOW WEATHERSTRIP & BODY PANEL - (No. 55)  1963-64-65 Corvette
Problem is of weatherstrip not fitting tight to the body panel causing gaps at right and left side, permitting water and air entry.
Correction being worked out.  Involves replacing seal with a newly designed seal which is not yet available.
