1963 Corvette: Service Bulletin: Parking Brake Cable Clip Retention
Estimated Reading Time: 1 Minutes Model Year: 1963 Corvette
Subject: Parking Brake Cable Clip Retention
Source: Chevrolet Central Office Technical Service Bulletin
Number: DR #608, Section V
Date: June 29, 1963
To: All Chevrolet Dealers
The 1963 Corvette right hand parking brake cable housing is retained to the frame crossmember at the forward end by a U-shaped clip (see 1963 Corvette Shop Manual, page 5-3, fig. 5). During application of the parking brake, movement of the cable housing may allow this U-shaped clip to work loose. Loss of retention will permit the cable to pass through the crossmember resulting in continuous brake drag and subsequent failure.
To prevent this retainer clip from working loose, drill a 7/32" hole and install a 1/4" x 20 self-tapping screw, Part No. 9411890, as illustrated.
