1968 Corvette: Engineering Service Letter: Engine Harness Replacement Corvette Transistor Ignition
Estimated Reading Time: < 1 MinuteSubject: Engine Harness Replacement Corvette Transistor Ignition
Model and Year: 1968 Corvette K66 (#960) (S.N.)
Date: NA
There is no separate released engine harness for subject option [RPO K66]. Production reworks the base harness whenever the option is built. The same rework is also required in service since the base harness is the service part.
Because of the above, to assist in the installation, an instruction sheet will be included in the new service replacement harness P/N 6295276.
