1968 Corvette L88: ESL Bulletin: Front End Roll During Hard Cornering
Subject:  Front End Roll During Hard Cornering
Model and Year: 1968 Corvette with RPO L-88
Source: E.S.L. Bulletin
Bulletin No: 963 (T.N.)
Date: 68-10-3
FRONT END ROLL DURING HARD CORNERING - 1968 Corvette w/RPO L88
(#963) (T.N.)
It has come to our attention that the base production 327 type front stabilizer shaft could have been installed on some L88 equipped Corvettes built before 5-2-68.  This installation can result in a reduction of front roll stiffness which may be noticeable to the more astute driver.  In the event of a complaint of this nature, the front stabilizer shaft diameter should be measured.  If the shaft measures 3/4" diameter instead of 15/16" diameter, then the following parts should be installed:
QUANTITY     PART NO.     NAME
1                       3831972      Front Stabilizer Shaft (15/16" diameter)
2                       3923674      Bushing
