1968 Corvette: Service Bulletin: Power Steering Bracket
Estimated Reading Time: 1 MinutesSubject: Power Steering Bracket
Model and Year: 1968 Corvette with 427 cu. in. Engine
Bulletin Number: 68-T-46, Section IX
Date: Apr. 25, 1968
TO: AL CHEVROLET DEALERS
Some reports of power steering pump rackets cracking and/or breaking have been received on 1968 Corvettes equipped with 427 Cu. In. engine.
Effective in production since late March, a redesigned bracket has been used to correct the above condition.
In service when cracked or broken power steering pump brackets are encountered, they should be replaced with the following:
PART NO. |
DESCRIPTION |
QUANTITY |
3946000 | Brace | 1 |
3946002 | Bracket | 1 |
