1969 Corvette: Engineering Service Letter: Speedometer Shaft Failure
Estimated Reading Time: < 1 MinuteSubject: Speedometer Shaft Failure
Model and Year: 1969 Corvette w/ 4-Speed Transmission
Date: NA
UPC XII - ELECTRIC AND INSTRUMENTS
E.S.L.
SPEEDOMETER SHAFT FAILURE - 1969 Corvette w/ 4-Speed Transmission (#1106) (D.S.T.)
The failures have been attributed to kinking of the cable (transmission end) at time of installation. For interim 1969 Production, Engineering has released a new 5 inch longer cable and defined the routing to eliminate possibility of kinking.
