1974 - 1975 Corvette: Service Bulletin: Stripped Speedometer Driven Gear
Estimated Reading Time: 1 MinutesSubject: Stripped Speedometer Driven Gear
Model and Year: 1974 - 1975 Corvette with 4-Speed Transmission
Bulletin No: 75-T-3
Section: XII
Date: January 17, 1975
To: All Chevrolet Dealers:
On 1974 and 1975 Corvettes with 4-speed transmission, an inoperative speedometer due to a stripped riven gear may be the result of high internal friction in the speedometer adapter.
A new low friction adapter and key will be phased into production in January, 1975 and will be available for service under the numbers listed below:
1565211 ---- Adapter
6476970 ---- Key
For service, vehicles exhibiting this problem may be corrected by the following method:
- Remove driven gear and replace with new gear of same part number and color.
- Remove and discard production adapter and key and install new adapter and key.
