1974 Corvette: Service News: Removal of Corvette Front Speakers
Estimated Reading Time: 1 MinutesSubject: Shop Manual Procedure Revised - Removal of Corvette Front Speakers 1974 Models
Model and Year: 1974 Corvette
Bulletin Number: Volume 45, November 1973, Number 11
The front speaker removal procedure found on page 15-8 of the 1974 Chevrolet Passenger Car Service Manual has been revised.
The revised procedure is as follows:
Corvette Speaker (Left Side)
Replacement
- Disconnect battery ground cable.
- Loosen windshield top garnish molding and remove windshield left side and right side garnish moldings.
- Remove right side dash pad.
- Remove one screw from instrument panel reinforcement and one screw from center console.
- Lift up on instrument panel top pad and disconnect speaker connection.
- Remove instrument panel.
- Remove screws securing speaker to underside of instrument panel pad and then remove speaker.
- To reinstall, Reverse Steps 1-7.
CAUTION: Always attach speaker connection before applying power to radio. - Check speaker operation.
Corvette Speaker (Right Side)
Replacement
- Remove three upper screws and two outer screws securing right dash pad. Pull dash pad out slightly to expose speaker and speaker connector.
- Disconnect speaker connector.
- Remove four nuts on underside of instrument panel pad securing speaker and remove speaker.
- To reinstall, Reverse Steps 1-4.
CAUTION: Always attach speaker connector before applying power to radio. - Check speaker operation.
