1978 - 1979 Corvette: Service Bulletin: Power Antenna Operation
Estimated Reading Time: 2 Minutes Subject: Power Antenna Operation
Model and Year: 1978-79 Vehicles with CB or RPO U75
Bulletin No: 79-T-8
Section: XII
Date: April, 1979
Extreme cold weather and/or excessive buildup of dirt/corrosion may cause a power antenna to stick and fail to extend or retract completely.
Complaint vehicles should be corrected as follows:
- Thaw unit as required if problem occurred during extremely cold weather.
- Extend mast. This may require manually assisting the mast when antenna unit is energized.
- Clean mast sections thoroughly to remove any water or dirt. Note: It may be necessary to use fine steel wool to remove any corrosion residue that may exist.
- Extend and retract antenna mast several times repeating steps 2 and 3 until mast stays clean and dry.
- With mast fully extended (triband - 36" from fender surface, A<-FM - 33" from fender surface), lubricate entire surface of mast sections liberally, especially the section joints, with one of the following:
- a. Spray silicone (Pen Ray or equivalent)
- b. Liquid graphite (Lock Ease or equivalent)
- Operate antenna up and down several times, then wipe off excess lubricant.
Time for correction: .2 hours.
Chevrolet Motor Division
General Motors Corporation
