1981 Corvette: Repairing Driver Side Sun Visor
Estimated Reading Time: 1 Minutes1981 Corvette: Repairing Driver Side Sun Visor
Submitted by: bill81vette
With a small screw driver pop off the plug covering the top hole where the visor keeps falling out of.
- Remove the old clip(its probably broken) and the spring.
- Place the new spring and clip (I put it in with the collar down) into hole and push up on the visor.
- With a small socket push down on the clip pops into place,(I used a small 3/8’s socket about on a handle to push this down with).
- Replace plug cover
Took about 5 minutes to change.
ONE WORD OF CAUTION...IF you don’t get the clip into place the first try. IT WILL LAUNCH itself. I found the pieces a few weeks later and tried again. So far, it has worked!!!!!!
