1982 Corvette: ECM Codes
Estimated Reading Time: < 1 MinuteCode #12: Normal System No Codes.
Code #13: Oxygen Sensor Circuit.
Code #14: Coolant Sensor Circuit Low.
Code #15: Coolant Sensor Circuit High.
Code #21: Throttle Position Sensor High.
Code #22: Throttle Position Sensor Low.
Code #24: Vehicle Speed Sensor.
Code #33: Manifold Absolute Pressure Sensor Signal High.
Code #34: Manifold Absolute Pressure Sensor Signal Low.
Code #42: Electronic Spark Timing.
Code #43: Electronic Spark Control.
Code #44: Lean Exhaust Indication.
Code #45: Rich Exhaust Indication.
Code #51: PROM Error.
Code #55: Defective ECM.
