1984 - 1985 Corvette: Service Bulletin: Corvette Door Trim Panel Moldings
Estimated Reading Time: 1 MinutesModel Year: 1984-1985
Subject: Door Trim Panel Upper Garnish Molding
Number: 85-136, Section 10
Date: Oct., 1985
To: All Chevrolet Dealers
The side front door trim panel assembly has been replaced when only the garnish molding needed replacement. To correct this needless replacement of panel assemblies, upper garnish molding are now available.
P/N | Part Name |
14094585 | Molding - Door Trim Panel Upper Garnish (L.H.) |
14094586 | Molding - Door Trim Panel Upper Garnish (R.H.) |
To replace garnish molding, remove the door trim panel per instructions in Corvette Shop Manual.
Labor Time: .5 hours each side
Chevrolet Motor Division
General Motors Corporation
