1984 - 1985 Corvette: Service Bulletin: Door Ajar Switch Corrosion
Estimated Reading Time: 1 Minutes Model Year: 1984-1985
Subject: Door Ajar Switch Corrosion
Bulletin Number: 85-43, Number 8B (XII) & 10(I)
Date: Feb., 1985
SOME 1984 AND EARLY PRODUCTION 1985 CORVETTE DOOR AJAR SWITCHES (P/N 14062556) MAY BECOME INOPERATIVE DUE TO INTERNAL CORROSION. THIS CAUSES THE DOOR AJAR LIGHT TO EITHER BECOME INOPERATIVE, FLICKER, OR STAY ON.
A NEW CORROSION RESISTANT SWITCH (P/N 14087681) AND AN ASSOCIATED RETAINER (P/N 14087682) ARE TO BE USED AS SERVICE REPLACEMENTS. THE NEW SWITCH INCLUDES A SLEEVE (SEE ILLUSTRATION) THAT FITS TIGHTLY AROUND THE SWITCH’S HOUSING AND HAS SUFFICIENT LENGTH TO COVER THE WIRE CONNECTOR ONCE CONNECTION TO THE DOOR HARNESS IS MADE.
WHEN REPLACING THE EXISTING SWITCH WITH A NEW 14087681 SWITCH, THE DOOR INSERT HOLE WILL NEED TO BE ENLARGED FROM 16MM TO 18MM TO ACCOMMODATE THE SLEEVE PROVISION. CARE MUST BE EXERCISED WHEN ENLARGING THE INSERT HOLE SO THAT ADJOINING MOUNTING HOLES ARE NOT ALTERED. SCRATCHES, CHIPS, ETC., TO DOOR PANEL SURFACE RESULTING FROM THE HOLE ENLARGING PROCESS ARE TO BE COSMETICALLY REPAIRED AS OUTLINED IN SECTION 10 (BODY) OF THE CORVETTE SHOP MANUAL.
