1984 - 1986 Corvette: Service Bulletin: Power Seat Adjuster Excessive Movement
Estimated Reading Time: 1 MinutesSubject: Power Seat Adjuster - Excessive Movement
Model and Year: 1984 - 1986 Corvette
Source: Chevrolet Dealer Sevice Bulletin
Bulletin Number: 86-117, Section 9 & 8B
Date: July, 1986
Customer comments of excessive movement of seat adjusters on 1984 to 1986 Corvettes can be repaired by replacing the seat adjuster transmission assembly, P/N 10065222.
The condition is due to excessive gear clearances within the transmission assembly.
