1984 - 1996 Corvette: Roof Panels - VIN Etching
From Jerry Watts, retired GM Corvette Action Center Staff Member:
"The factory did start numbering the see thru roofs, because they were a high theft item. Look on the left front corner of the frame, if it is an original factory top it should have the same last 8 numbers as your vin number on the dash."
