1984 - 1996 Corvette: Service Bulletin: Chattering Wiper Blades or Wipeability
Subject: CHATTERING WIPER BLADES OR WIPEABILITY
Model and Year:ALL PASSENGER CARS AND TRUCKS
Bulletin Number: 91-126-8E - (12/31/1990)
Condition:
Chattering and poor wipeability comments may be due to the windshield glass and/or wiper blades becoming contaminated by insect residue, dirt, road grime, carwax etc.
Correction:
1. Clean the windshield glass with GM #1 050011 (Bon Ami) glass cleaner or equivalent.
IMPORTANT: The glass is clean when rinse water does not "bead-up," but "sheets" across the entire glass surface. Multiple cleanings may be required to remove all contaminants.
2. Clean the wiper blades by using a cloth that has been saturated with full strength washer solution and wipe vigorously. Rinse the blades with water after cleaning.
