1984 - 1996 Corvette: Technical Article: How to Replace Your Front Brakes
by Lars Grimsrud
©2010 Lars Grimsrud.
This article may not be published or distributed without the written permission of the author
Rev. B 1-2-10
This tech paper will discuss the replacement of the front brake pads and rotors on the C-4 Corvettes.  This paper deals specifically with the ’84 - ’87 model years, and applies generally to the ’88 through ’96 models.  The rear brakes use the same process, so you can use this procedure as a guide for the rear, as well.
See attachment below:
  • Attached Files
  • c4_brakes_tech_paper.pdf (185.22 KB) 944
