1984 - 1996 Corvette: Water Leakage: Preventing Water Leaks Into the Interior Near Side Windows
Estimated Reading Time: < 1 MinuteOn the upper right hand corner of each side glass near the top of the windshield, you will see a triangular shaped piece of black plastic. Gently try to bend these pieces down a bit in order to crimp the rubber down a little more. This may help.
