1984 Corvette: Service Bulletin: Dealer Installed Anchor for Child Seat with Top Strap Anchor Installation
Subject:   Dealer Installed Anchor for Child Seat with Top Strap Anchor Installation
Model and Year:   1984 Corvette
Source:  Chevrolet Dealer Service Technical Bulletin
Bulletin No:  84-121
Section:   10 (I)
Date:  May 1984
TO:  ALL CHEVROLET DEALERS
Should a customer request the installation of a child seat top tether anchor, in their 1984 Corvette, the following installation steps are to be performed:
  1. Remove rear floor carpet and insulator.
  2. Drill a 9mm (11/32 inch) diameter hole through the front at the location shown in Figure #1.  CAUTION:   Double check hole location to avoid damage to the vehicle under-carriage components.
  3. Reinstall insulator, cut 38mm (1 1/2 inch) diameter hole for washer/spacer*.  Reinstall the carpet and cut a 9mm (11/32 inch) diameter hole for the anchor attachment bolt.
  4. Using a suitable sealer, such as silicone or butyl type caulking, apply a bead of sealant around the 9mm (11/32 inch) drilled hole in the floor pan.  NOTICE:   The sealant is to be applied on the outer side of the floor pan (see Figure #2).
  5. Install the tether anchor bracket, as shown in Figure #2, and tighten nut securely.  NOTICE:   In the event the tether anchor assembly is removed, the 9mm diameter hole must be properly resealed to prevent exhaust fumes from entering the vehicle.
* Washer/spacers (not supplied):
Three (3) flat washers 32 mm (1 1/4 inch) x 3mm (1/8 inch) thick, with a 9mm (11/32 inch) diameter hole.  Total stack-up of washer/spacer is to be 9.5mm (3/8 inch).
Chevrolet Motor Division
General Motors Corporation
1984 Corvette Dealer Installed Anchor for Child Seat with Top Strap Anchor Installation
