1984 Corvette: Service Bulletin: Revised Rocker Arm Cover Removal Procedures - Right Side
Model Year: 1984
Subject: Revised Rocker Arm Cover Removal Procedures - Right Side
Number: 3, Volume 56
Date: May/June 1984
Revised Rocker Arm Cover Removal Procedures - Right Side - 1984 Corvette Models With 5.7L V-8 Engines.
The subject procedures called out in Section 6A1, Page 6A1-6 of the 1984 Corvette Shop Manual (ST-364-84) have been revised as shown below. Please make a note of this change in your copy of the Shop manual.
Removal
  1. Disconnect battery ground cable.
  2. Remove Air cleaner.
  3. Disconnect the A.I.R. pipe at the switching valve.
  4. Disconnect wires at the high pressure switch.
  5. Remove the high pressure switch.
  6. disconnect E.G.R. solenoid at the intake manifold.
  7. Disconnect C.F.I. harness at rosebud on rocker arm cover.
  8. Remove rocker arm cover bolts.
  9. Remove rocker arm cover.
Installation
Refer to Installation procedures show on Page 6A1-6 of the 1984 Corvette Shop Manual (ST-364-84).
