1985 - 1991 Corvette: Service Bulletin: Paint Etching/Staining and Permanent Water Spotting
Subject: PAINT ETCHING/STAINING AND PERMANENT WATER SPOTTING
Model and Year:1985-91 ALL PASSENGER CARS AND TRUCKS
Bulletin Number: 91-251-0B - (03/12/1991)
A recent long term investigation has indicated that improper car wash procedures contribute to paint staining, etching and permanent water spotting.
Dealer personnel in both new and used car facilities should be advised of the following:
- Avoid washing cars in direct sunlight
- Avoid using strong soaps or chemical detergents
- Avoid using products containing acids
- Cleaning agents should be dried promptly and not allowed to dry on surface
- Standing rinse water should be dried promptly and not allowed to air dry or sun dry on surface
- Drying with a soft chamois is recommended
Should a customer inquire about proper washing procedures, the above recommendations should be given and are in accordance with the information in the owners manuals.
