1985 Corvette: Service Bulletin: Rear Exhaust Hanger Bolt Falls Out
Estimated Reading Time: 2 Minutes Subject: Rear Exhaust Hanger Bolt Falls Out
Model and Year: 1985 Corvette
Bulletin Number: 85-125, Section 6F
Date: Sept., 1985
CONDITION
The rear exhaust hanger bolt may fall out on some early 1985 Corvettes.
CAUSE
The condition may be caused by loss of clamp load.
CORRECTION
- Add four (4) 8mm (5/16") phosphate coated flat washers between the hanger insulator and bumper extension. The washers are added to prevent the insulator metal sleeve from pulling into the adjusting slot on the bumper extension (See Illustration).
NOTICE: Only use coated washers to prevent corrosion between the washer and the bumper extension.
- Replace the four (4) original nuts with four (4) M8-1.25 torque prevailing nuts. Torque nuts to 35 ft. lbs. (34 N.m).
- If the original bolts are missing, replace with M8 x 1.25 x 45mm flanged hex head bolts.
PRODUCTION CHANGE
This change was put into production on April 2, 1985, VIN #123542.
Labor Operation No: L2020
Labor Time: .3 hours
PARTS REQUIRED
Nut - #11500760 - 4 Req’d.
Washer - #11500323 - 4 Req’d.
Bolt - #14066303 - As Req’d.
Bracket - #14087698 - As Req’d.
Insulator - #14076189 - As Req’d.
Chevrolet Motor Division
General Motors Corporation
