1986 - 1987 Corvette: Service Bulletin: Clutch Master Cylinder Push Rod Bushing
Subject:  Clutch Master Cylinder Push Rod Bushing
Model Year:   1986 - 1987 Corvette with Manual Transmission
Bulletin No: 87-114, Section 7C
Date: April, 1987
TO:  ALL CHEVROLET DEALERS
Some 1986 or 1987 Corvettes with manual transmissions may experience inadequate retention of the clutch master cylinder push rod attachment.
If the condition exists, remove the plastic bushing from the master cylinder push rod and replace with the following service parts.  (Refer to Figure 1):
DESCRIPTION PART NUMBER
Bushing 14080233
Flat Washer 120395
Retainer 148149
Use applicable Labor Time and Operation Number.
Chevrolet Motor Division
 General Motors Corporation
1986 - 1987 Corvette Clutch Master Cylinder Push Rod Bushing
  1. A little click when I push on the clutch pedal revealed the retainer sliding on the bushing. I thought I might try this fix instead of replacing the stock bushing and retainer. This is the first time this has been an issue in over 30 years, though. Can these parts be readily found?
