1988 Corvette: Service Bulletin: Service Manual Update Front Leaf Spring Compressor Adapter
Estimated Reading Time: 1 Minutes Model Year: 1988 Corvette
Subject: Service Manual Update Front Leaf Spring Compressor Adapter
Source: Chevrolet Dealer Service Update Bulletin
Bulletin Number: 88-272-3C, Number 3C
Date: Aug, 1988
A new front leaf spring compressor adapter, J33432-88, has been developed and will be available approximately 9/15/88 from Kent-Moore, for use on all 1988 Corvettes. This adapter can be used with existing front leaf spring compressor, J33432. The new adapter was released due to the wider front transverse spring on the 1988 Corvette.
These new adapters may be used on all Corvette front transverse springs from 1984 - 1988.
