1990 - 1991 Corvette: Service Bulletin: Hard Start on Hot Restart / Increased Idle Speed
Estimated Reading Time: 1 MinutesSubject: HARD STARTING DURING A HOT RESTART, INCREASE IN IDLE SPEEDS, AND IDLE FLUCTUATION (REPLACE MEM-CAL)
Model and Year: 1990-91 CHEVROLET CORVETTE WITH 5.7L ENGINE (VIN J - RPO LT5) AND MANUAL 6-SPEED TRANSMISSION (ML9)
Bulletin Number: 47-65-03 - (01/24/1994)
CONDITION:
SOME OWNERS OF 1990 CORVETTES MAY COMMENT ON IDLE FLUCTUATION, INCREASE IN IDLE SPEED AFTER A HOT RESTART, AND AN INCREASE IN ENGINE SPEED DURING A VEHICLE COAST TO STOP WITH CLUTCH DEPRESSED.
SOME OWNERS OF 1991 CORVETTES MAY COMMENT ON A HARD STARTING CONDITION DURING A HOT RESTART.
CORRECTION:
THE CALIBRATIONS HAVE BEEN REFINED TO ADDRESS THESE CONCERNS. REPLACE THE MEM-CAL WITH THE DESIRED UNIT FROM THE CHARTS BELOW.
PART INFORMATION:
MODEL BROADCAST SCANNER PART BODY YEAR CODE I.D. NUMBER STYLE AXLE
1990 AYBK 3921 16163905 COUPE 3.45
1991 BFXB 3431 16193416 COUPE 3.45
PARTS ARE CURRENTLY AVAILABLE FROM GMSPO.
WARRANTY INFORMATION:
LABOR OPERATION: T0500 LABOR TIME: 0.5 HOUR
