1990 Corvette: Recall: Inoperative Parking Brake
Estimated Reading Time: 7 Minutes
Subject: CAMPAIGN: INOPERATIVE PARKING BRAKE
Model and Year: 1990 CHEVROLET CORVETTE
Bulletin Number: 90-C-09 - (01/24/1990)
General Motors has determined that certain 1990 Chevrolet Corvette model vehicles may exhibit an inoperative parking brake upon attempted engagement. This is due to the cable button pulling through and separating from the nylon reel resulting in an inoperable parking brake. This separation is a time related condition dependent on the number of parking brake applications, and occurs only upon parking brake application, not under sustained load conditions.
To correct this condition, a new parking brake lever assembly will be installed on the involved vehicles.
VEHICLES INVOLVED
Involved are certain 1990 Chevrolet Corvette model vehicles built within the following VIN breakpoints:
MODEL/YEAR PLANT FROM THROUGH OPTION
Y 1990 Bowling Green L5100001 L5100887 L98 Engine
Y 1990 Bowling Green L5800001 L5800120 LT5 Engine
Involved vehicles have been identified by Vehicle Identification Number Computer Listings. Computer listings contain the complete Vehicle Identification Number, owner name and address data, and are furnished to involved dealers with the campaign bulletin. owner name and address data furnished will enable dealers to follow-up with owners involved in this campaign.
OWNER NOTIFICATION
Owners will be notified of this campaign on their vehicles by Chevrolet Motor Division. Some owners will receive letters addressing more than one campaign on their vehicle (see copies of owner letters included with this bulletin) as shown in the chart below.
VIN Range Campaigns Addressed In Owner Letters
L5800001 - L5800120 90CO7 / 90CO9 / 9OC10
L5100001 - L5100887 90CO7 / 90CO9
Whenever a vehicle subject to this campaign is taken into your new or used vehicle inventory, or it is in your dealership for service in the future, you should take the steps necessary to be sure the campaign correction has been made before reselling or releasing the vehicle.
Owners of vehicles recently sold from your new vehicle inventory are to be contacted by the dealer, and arrangements made to make the required correction according to instructions contained in this bulletin.
PARTS INFORMATION
Parts, when required, are to be obtained from General Motors Service Parts Operations (GMSPO). To ensure parts will be obtained as soon as possible, they should be ordered from GMSPO on a "C.I.O." order with no special instruction code, but on an advise code (2).
Quantity/ Part Number Description Vehicle
10097695 Parking Brake Lever Assembly 1
SERVICE PROCEDURE
1. Replace parking brake lever assembly referring to Section 5 of the 1990 Corvette Service Manual.
2. Install Campaign Identification Label.
CAMPAIGN IDENTIFICATION LABEL
Each vehicle corrected in accordance with the instructions outlined in this bulletin will require a "Campaign Identification Label". Each label provides a space to include the five (5) digit dealer code of the dealer performing the campaign service. This information may be inserted with a typewriter or a ball point pen.
Each "Campaign Identification Label" is to be located on the radiator core support in an area which will be visible when the vehicle is brought in for periodic servicing by the owner.
Apply "Campaign Identification Label" only on a clean dry surface.
CLAIM INFORMATION
* FAILED PARTS CC-FC LABOR LAB OTH REPAIR PERFORMED PC PART NO. ALLOW OP HRS HRS ---------------- -- -------- ----- ----- -- --- --- Install new parking brake assembly 1 10097695 SK-00 V5740 0.7 0.1
* Campaign Administrative Allowance
** The "Parts Allowance" should be the sum total of the current GMSPO Dealer Net price plus 30% of all parts required for the repair.
Dear Chevrolet Corvette ZR1 Owner:
REASON FOR THIS RECALL
General Motors has determined that a defect which relates to motor vehicle safety exists in certain 1990 Chevrolet Corvette ZR1 model vehicles. The fuel feed and return line connectors of these vehicles were built with the incorrect line end flare configuration. If these lines are left uncorrected, the line ends could crack causing a fuel leak which may result in an engine compartment fire.
Additionally, two other non-safety recalls will be performed on your vehicle while it is in for fuel line corrections. First, parking brakes on some 1990 Chevrolet Corvette ZR1s may become inoperable due to the cable button pulling through and separating from the nylon reel to which it is attached. This condition occurs on application only, not under sustained load conditions. The condition will be obvious due to a lack of resistance during parking brake application.
Finally, some 1990 Chevrolet Corvette ZR1s may experience instrument panel wires rubbing on the hood release cable bracket causing wire abrasion. If this condition continues to exist, the instrument panel wiring may wear through and ground itself on the hood release cable bracket, possibly causing a short in the vehicles electrical system and an inoperable vehicle engine.
WHAT WE WILL DO
To prevent the possibility of a fuel leak occurring, new fuel lines with the correct end flare configuration will be installed on the involved vehicles. Also, a new parking brake assembly will be installed, and protective electrical tape will be applied to the instrument panel wiring and hood release cable bracket, thus protecting the wires from abrasion. Additionally, instrument panel wiring which shows signs of abrasion will be repaired.
These services will be performed for you at no charge.
WHAT YOU SHOULD DO
Your authorized Chevrolet Corvette ZR1 Dealer will be contacting you soon to arrange a service date if it has not already done so. Instructions for making these corrections have been sent to this dealer along with parts to complete these repairs. The labor time to perform the necessary service corrections is approximately 2 hours. Your dealer can inform you of any additional time needed to schedule and process your vehicle.
Your authorized Chevrolet ZR1 Dealer is best equipped to obtain parts and provide service to insure that your vehicle is corrected as promptly as possible. However, if you take your vehicle to your dealer on the agreed service date, and they do not remedy this condition on that date or within five (5) days, we recommend you contact the Chevrolet Customer Assistance Center by calling 1-800-222-1020.
After contacting your dealer and the Customer Assistance Center, if you are still not satisfied that we have done our best to remedy this condition without charge and within a reasonable time, you may wish to write the Administrator, National Highway Traffic Safety Administration, 400 Seventh Street, S.W., Washington, D.C. 20590 or call 1-800-424-9393 (Washington D.C. residents use 366-0123).
The enclosed owner reply card identifies your vehicle. Presentation of this card to your dealer will assist in making the necessary correction in the shortest possible time. If you have sold or traded your vehicle, please let us know by completing the postage paid reply card and returning it to us.
