1990 Corvette ZR-1: Service Bulletin: Leaking Radiator Hose Service
Estimated Reading Time: 1 MinutesSubject: LEAKING RADIATOR HOSE SERVICE (REPLACEMENT OF RADIATOR HOSE)
Model and Year: 1990 CORVETTE WITH 5.7L (VIN CODE J) ENGINE
Bulletin Number: 90-308-6B - (07/19/1990)
Condition:
Some of the above vehicles, prior to VIN L5800913, may exhibit coolant leaks at the radiator hose attachments.
Cause:
This leak condition is caused by a torque loss of the radiator hose clamp (screw worm drive type), combined with the permanent set characteristics of the radiator hose material, in cold weather ambiences of twenty (20) degrees "F" and lower.
Correction:
If one or more of the radiator hoses are leaking, all the radiator hoses should be replaced with a new Service Kit, P/N 10157951. This kit includes six (6) new radiator hoses and twelve (12) new spring type hose clamps.
Use the Service Manual procedures for the removal and replacement of radiator hoses.
Labor Operation Number: T1607
Labor Time: 1.4 Hours
