1991 Corvette: Service Bulletin: Information / Installation of Underhood / Courtesy Lamp
Estimated Reading Time: 1 Minutes Subject: INFORMATION/INSTALLATION OF UNDERHOOD/COURTESY LAMP FUSE
Model and Year: 1991 CORVETTE
Bulletin Number: 91-116-8C - (11/14/1990)
The underhood lamp fuse on the 1991 Y car is not installed at the factory. It is included in a card attached to the rearview mirror, and should be installed in the fuse receptacle under the hood, behind the left marker lamp, as shown in the illustration. Installation of this fuse is part of the New Vehicle Preparation (NVP), and SHOULD NOT BE CLAIMED UNDER WARRANTY.
The Courtesy lamp fuse, which was installed by the dealer for the 1990 Y car, is now installed by the assembly plant.
