1992 Corvette: Service Bulletin: Engine Backfire During W.O.T. 1-2 Upshift
Estimated Reading Time: 1 MinutesSubject: ENGINE BACKFIRE DURING W.O.T. 1-2 UPSHIFT (RPL. MEMCAL)
Model and Year: 1992 CORVETTE WITH 5.7L ENGINE (RPO LT1) AND AUTOMATIC TRANSMISSION
Bulletin Number: 92-336-6E - (12/01/1992)
CONDITION:
Some owners of 1992 Corvettes with the LT1 (VIN P 5.7L V8) engine and automatic transmission may comment on an engine backfire during a wide open throttle (W.O.T) 1-2 upshift.
CORRECTION:
The calibration has been refined to address this concern, replace the memcal with the appropriate one from the chart below.
Broadcast Scanner Part Body Code I.D. Number Style Axle
BDBJ 4681 16184669 Coupe G44
BDBK 4691 16184672 Coupe/Conv GM1
BCBL 4701 16184678 Coupe/Conv GU2
BDBF 4661 16184667 Conv G44
