1993 - 1994 Corvette: Service Bulletin: Intermittent ASR Service Light
Subject: INTERMITTENT ASR SERVICE LIGHT (REPLACE MEM-CAL)
Model and Year: 1993-94 CHEVROLET CORVETTE WITH 5.7L ENGINE (VIN J - RPO LT5) AND MANUAL 6-SPEED (ML9) TRANSMISSION
Bulletin Number: 47-50-01
CONDITION:
SOME OWNERS OF 1993-94 CORVETTES BUILT BEFORE NOVEMBER 24, 1993 (VIN 1G1YZ12J8R5800090) MAY COMMENT ON SEEING AN ASR SERVICE LIGHT INTERMITTENTLY IMMEDIATELY AFTER VEHICLE START UP.
CORRECTION:
INSTALL THE MEM-CAL LISTED BELOW. IF AN ASR SERVICE LIGHT IS STILL PRESENT, IMMEDIATELY AFTER START-UP, FURTHER PROBLEM DIAGNOSIS SHOULD BE FOLLOWED USING INSTRUCTIONS IN THE SERVICE MANUAL.
PART INFORMATION:
BROADCAST SCANNER PART BODY CODE I.D. NUMBER STYLE AXLE
BKKR 1416 16201452 COUPE 3.45
PARTS ARE CURRENTLY AVAILABLE FROM GMSPO.
WARRANTY INFORMATION:
LABOR OPERATION: T0500 LABOR TIME: 0.5 HOUR
