1994 - 1995 Corvette: Service Bulletin: Information on Air Intake Duct Installation
Estimated Reading Time: 1 MinutesModel Year: 1994-95 BUICK ROADMASTER 1994-95 CADILLAC FLEETWOOD 1994-95 CHEVROLET CORVETTE, CAPRICE, CAMARO 1994-95 PONTIAC FIREBIRD WITH 4.3L AND 5.7L ENGINES (VINS W, P - RPOS L99, LT1) AND 4L60-E/MANUAL TRANSMISSION (RPOS MM6/ML9)
Bulletin Number: 57-65-02
WHEN SERVICING THE AIR DUCT ASSEMBLY, CARE MUST BE TAKEN WHEN INSTALLING THE AIR DUCT TO THE THROTTLE BODY. IT MAY BE POSSIBLE TO FOLD THE LOWER LIP OF THE AIR DUCT AS IT IS SLID OVER THE THROTTLE BODY CAUSING UNMETERED, NONFILTERED AIR TO ENTER THE INTAKE MANIFOLD. THIS CONDITION COULD CAUSE AN MIL TO SET OR A CUSTOMER DRIVEABILITY CONCERN.
WHEN INSTALLING THE AIR DUCT ASSEMBLY TO THE THROTTLE BODY, LUBRICATE THE AIR DUCT WITH A SOAPY WATER SOLUTION.
**NOTICE:** DO NOT USE ANY TYPE OF SILICONE SOLUTIONS. THEY CAN CAUSE CONTAMINATION TO THE OXYGEN SENSORS.
AFTER THE AIR DUCT IS INSTALLED, VISUALLY INSPECT THE AIR DUCT TO BE SURE IT IS PROPERLY SEALED AROUND THE THROTTLE BODY.
